Krivas
Feb 04, 2021Initiate
ORBI AX600 - WIFI Printer EXPSON AX 7100 problem
A few weeks ago I installed an new Orbi AX6000 system with one satelite RBR852. Then I tried to install my old Canon MX455 printer without succes. I thought, the printer was to old, so I bought a new...
- Feb 04, 2021
Glad you got it working. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
Feb 04, 2021Guru - Experienced User
Your desktop PC should be conneted to the Orbi system.
Contact the printers mfr for additional help and information regarding there product.
- KrivasFeb 04, 2021Initiate
Your desktop PC should be conneted to the Orbi system. .... that was the problem. Now my modem is out the bridge mode en the Orbi is in AP-mode and it is working. But not actualy the way I want it... so I thing I will buy an USB-WIFI adaptor for my desktop, that wil also work, is me told...
- FURRYe38Feb 04, 2021Guru - Experienced User
Enjoy. :smileywink:
- Mikey94025Feb 04, 2021Hero
Krivas wrote:Your desktop PC should be conneted to the Orbi system. .... that was the problem. Now my modem is out the bridge mode en the Orbi is in AP-mode and it is working. But not actualy the way I want it... so I thing I will buy an USB-WIFI adaptor for my desktop, that wil also work, is me told...
It sounds like your PC needs a wired network connection and that's why you had it plugged into the modem. Have you tried plugging your PC into one of the Orbi's network ports? You want all your devices on the same network, i.e., your Orbi network, whether wired or wireless.
