PeterJT
Sep 25, 2020Follower
Orbi AX600 and Orange router
If I add the Orbi AX600 Mesh system to my Orange router, do I turn off DHCP on the Orange router, please? Tia
1 Reply
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try Option #2 on your Orange router...
