Airdrawn
Feb 07, 2021Aspirant
Orbi AX6000 - buy now??
Hi all, I am considering upgrading my Orbi to three AX6000 units. This seems to be the top of the range unit for high speed, reach and device numbers. I was wondering if now is a good time to buy g...
Chuck_M
Feb 08, 2021Mentor
The AX has been out for a while now and the firmware has gone through a series of significant updates -- if you need a system, I would suggest to make the move -- but clearly that is based on your requirements.
I for one had previously upgraded from an RBR-50 with 3 x satellites and am very happy with the RBR-850's performance and capability -- and am connected to 3 x RBS-850s. Solid as a rock.
Having said that, there are nightmare stories out there. You may want to let folks on here know the kind of equipment you are planning on connecting to as there may be nuances. Specifically the ISP and model of cable modem etc you plan on connecting to.
