Airdrawn
Feb 07, 2021Aspirant
Orbi AX6000 - buy now??
Hi all, I am considering upgrading my Orbi to three AX6000 units. This seems to be the top of the range unit for high speed, reach and device numbers. I was wondering if now is a good time to buy g...
Airdrawn
Feb 08, 2021Aspirant
Thanks for the replies.
Im in Australia. I currently have an RBR50 network of three units. I have a 50mbit connection that will be increased to 100mbit soon. Current speeds are 6MB/s throughout the home. I have a long and narrow block with a double story period home with double brick walls. My number of connected devices are increasing as is my bandwidth so I wanted a modem setup that is future proof in terms of devices and speed, which is why I’m
Considering the AX6000. I don’t know if the model number will help my overseas friends - it’s a Telstra Smart Modem 2 with 4G backup connected with fibre to the premises on our national broadband network.
Feb 08, 2021Guru - Experienced User
Be aware of ISP modems with build in routers and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
