shaunwest42
Feb 21, 2021Follower
Orbi AX6000 and outdoor satellite compatability question
I have Orbi AX6000 system (Router and 2 x Satellite Extenders). I would like to increase the range outside of my property for external Cameras i have fitted that have a drop in / drop out connect...
Feb 21, 2021Guru - Experienced User
If you load up the RBSY with the extender mode FW, it will work with Orbi AX.
dekjason
Feb 22, 2021Aspirant
Is this verified? I was planning on upgrading to the AX6000 and talked to a Netgear rep before I did – she said it wouldn't work currently, but that they're working on a solution.
- FURRYe38Feb 22, 2021Guru - Experienced User
Someone posted not to long ago same question and they reported back saying it worked. You can do a search here to check that.
