GarrettD
Jan 09, 2024Aspirant
ORBI AX6000 coming up as public
I have been running Orbi for years. For the last few years I have run a Fibe modem straight to my ORBI, and then all of my internet access downstream from there. I have one router, one wired satellit...
Jan 09, 2024Guru - Experienced User
What do you mean by coming up as public?
What model orbi do you have? RBK850 or 860 series?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Something to contact Apple about for issues seen on there products.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- GarrettDJan 09, 2024AspirantScreenshot to show error Apple says comes on public networks
Firmware v4.6.14.3
Sagemcom big white “5628” but will have to confirm when home
Same CAT 6 I’ve been using for years.
Two RBS. One wired, one wireless.
2100sqft
Haven’t tried without RBS
Wired to wireless RBS and wireless have issue
2.4GHz Auto
5GHz 48
Apple sees this error in phones at hotels, or college kids in dorms. PC seeing same error.
I have done a number or reset attempts in all sorts of configurations including leaving it all off all day today, and turning whole house off for ten minutes, as well as sequencing modem, router, satellite.
I am at work right now but can provide more in a few hours, or tomorrow.- FURRYe38Jan 09, 2024Guru - Experienced User
The the ISP Modem. I Think thats a modem with built in router and wifi already.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...That ISP app is from your ISP, not from Orbi system. Something you need to contact your ISP about.
RBK850
It is a modem with router built in.
Wifi is disabled from the modem
I had this set up and running successfully for years.
I will have to dig further into modem configurations. The ISP forum was talking about a bug that may disable and reactivate the modem's wifi, which could have altered other settings.
