GarrettD
Jan 09, 2024Aspirant
ORBI AX6000 coming up as public
I have been running Orbi for years. For the last few years I have run a Fibe modem straight to my ORBI, and then all of my internet access downstream from there. I have one router, one wired satellit...
Jan 09, 2024Guru - Experienced User
What model orbi do you have? RBK850 or 860 series?
The the ISP Modem. I Think thats a modem with built in router and wifi already.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
That ISP app is from your ISP, not from Orbi system. Something you need to contact your ISP about.
GarrettD
RBK850
It is a modem with router built in.
Wifi is disabled from the modem
I had this set up and running successfully for years.
I will have to dig further into modem configurations. The ISP forum was talking about a bug that may disable and reactivate the modem's wifi, which could have altered other settings.
- FURRYe38Jan 09, 2024Guru - Experienced User
Disabling the wifi on the ISP router only does that. Does not remove the double NAT condition.
One of the 3 options should help. However again, might need to contact the ISP.
Good Luck.
