marine0816
May 04, 2020Aspirant
Orbi AX6000 detached garage no insulation
I know the operating range is 32 to 104 degrees(F). But I'm looking for any real world usage of the satellite in an enclosed in environment with no insulation. I know the previous gen has an outdoor version but I'm not interested in that. Putting it in the detached garage is the only way my nest and ring cameras will stay connected. My climate is Pennsylvania.Thanks
1 Reply
No experience here. If the garage is not insulated then depending upon wet and humidity conditions, this may impact operation of an indoor orbi system since it's designed and meant to be inside mostly insulated buidings where wet and humidity conditions are kept out and controlled.
