FreddiA3
Jan 02, 2022Follower
Orbi AX6000 dropped the internet connection and won't reconnect.
Purchased an Orbi AX6000 two days ago. Connected it and set up all the wifi connections around the house. Amazing speed, brilliant coverage of dead spots. Found I didn't need two satelites so wen...
Jan 02, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
