johnny_rumely
Jun 28, 2022Aspirant
Orbi AX6000 Ethernet Backhaul
Im having an issue using my Orbi AX6000 in ethernet backhaul, The two satellites are showing as offline when i open up the orbi app, and they don't show when i login through the website (orbilogi...
johnny_rumely
The two satellites are connected to a switch, due to lots of walls in my house, im putting a satellite on each floor (we have 3 floors) im connecting it via a switch, i have an ethernet cable plugged into a switch and then i have my orbi plugged into the switch, im doing this on each floor
Jun 29, 2022Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
What CAT# LAN cable are you using? CAT6 is recommended.
Check LAN cables and connections.
