btx_tx
Oct 04, 2021Aspirant
ORBI AX6000 Fast download, Slow upload
Model: RBR850 and 2x RBS850 Firmware: V4.6.3.16_2.0.51 Speed Test from Orbi Admin Panel: 932.7Mbps Download; 939.48Mbps Upload Speed Test from Macbook Air M1 (wireless): 738Mbps Download; 163Mbps...
Oct 04, 2021Guru - Experienced User
What connect rate speed is the mac book air connecting at with the RBR. I'd turn OFF the RBS temporarily to ensure the mac book connects to the RBR. Use the Opt key + Right Click on the wifi icon on the top tool bar on OSX to see additional information and the connection rate.
btx_tx
Oct 05, 2021Aspirant
TX Rate is 864Mbps
- FURRYe38Oct 05, 2021Guru - Experienced User
You should see near 1300Mbps or over. What the highest connection rate supported by Apple for this Mac Book? My 2018 supports 1300Mpbs. I usually see around 700Mpbs speed results.
- btx_txOct 05, 2021Aspirant
Interesting...my download speeds are great (700+mbps) but upload cannot seem to break 200mbps.
I checked my phones as well, 600+mbps download, ~150mbps upload.
I'm not sure what else to try...maybe it is a bug in the firmware?
Are wired speeds good on the up?
Is WMM enabled under Under Advanced Tab/Advanced Settings/Wireless Settings
What are the current CTS values?
