btx_tx
Oct 04, 2021Aspirant
ORBI AX6000 Fast download, Slow upload
Model: RBR850 and 2x RBS850 Firmware: V4.6.3.16_2.0.51 Speed Test from Orbi Admin Panel: 932.7Mbps Download; 939.48Mbps Upload Speed Test from Macbook Air M1 (wireless): 738Mbps Download; 163Mbps...
btx_tx
Oct 05, 2021Aspirant
TX Rate is 864Mbps
Oct 05, 2021Guru - Experienced User
You should see near 1300Mbps or over. What the highest connection rate supported by Apple for this Mac Book? My 2018 supports 1300Mpbs. I usually see around 700Mpbs speed results.
- btx_txOct 05, 2021Aspirant
Interesting...my download speeds are great (700+mbps) but upload cannot seem to break 200mbps.
I checked my phones as well, 600+mbps download, ~150mbps upload.
I'm not sure what else to try...maybe it is a bug in the firmware?
- FURRYe38Oct 05, 2021Guru - Experienced User
Are wired speeds good on the up?
Is WMM enabled under Under Advanced Tab/Advanced Settings/Wireless Settings
What are the current CTS values?
Yes, WMM is enabled and on wired my upload is 800+mbps.
CTS 64
Attached a couple screen shots.
