btx_tx
Oct 04, 2021Aspirant
ORBI AX6000 Fast download, Slow upload
Model: RBR850 and 2x RBS850 Firmware: V4.6.3.16_2.0.51 Speed Test from Orbi Admin Panel: 932.7Mbps Download; 939.48Mbps Upload Speed Test from Macbook Air M1 (wireless): 738Mbps Download; 163Mbps...
btx_tx
Oct 05, 2021Aspirant
macOS 11.6
CTS change did not make much of a difference.
The M1 Mac has AX capability.
Oct 05, 2021Guru - Experienced User
Would be a good test to see if there is any differences between AX mode enabled or disabled...
with AX mode, your connection rates should be at least 1300Mpbs...however check Apples web site or support pages to see what they support for connection rates on that model book for AX and AC modes. AC mode you should see 1300Mpbs at least at the RBR.
