westsdad
Sep 30, 2020Aspirant
Orbi AX6000 firmware V3.2.16.6_1.4.4 WiFi access sporadic
Home Setup Calix 716-GE1 ONT -> Orbi RBR850 -> Netgear XS512EM -> Netgear GS110EMX -> Orbi RBS850 x2 (All CAT7 cables and wire runs) Ever since firmware V3.2.16.6_1.4.4 was auto (forced) instal...
Sep 30, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
Or try a factory reset and setup from scratch been performed since last FW update?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://https://https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Any Orbi system doesn't have any FW update option to not enable it. It's enabled be default and NG only pushes major FW udpates. Minor ones are notifications and are at users descresion to install or not.
- westsdadSep 30, 2020Aspirant
Thanks for your response. See the responses below after your questions.
Has a power off for 1 minute then back on been performed since last update? Yes, and just did it again. Will monitor WiFi access for a few days and will hear from the kids if there are issues.
Or try a factory reset and setup from scratch been performed since last FW update? Yes, and just did it again. Will monitor WiFi access for a few days and will hear from the kids if there are issues.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. At least 30 feet with a floor between them and they are a wired backhaul across CAT7 wire and 10Gps Switch Ports.
- FURRYe38Oct 01, 2020Guru - Experienced User
You may also run into problems with your model switches you have in between the RBR and RBS.
These are managed switches.
Also both switches have green ethernet features:
"Energy Efficient Ethernet (IEEE802.3az)
support for maximum power savings"Something that can cause problems for wired RBS if in between.
Make sure you disable all IGMP protocols on the switches.
If you can, also disable Green ethernet as well.
- westsdadOct 01, 2020Aspirant
Thanks again FURRYe38 for your response.
I checked the switches and Power Saving Mode was Disabled on them.
IGMP Snooping was Enabled. Changed it to Disabled.
