burnz123
Feb 06, 2020Follower
Orbi AX6000-Is it compatible with FIOS
Is this product compatible with FIOS? If so, is there set up directions available somewhere to assist me in the set up?
It should. Sometimes you have to change some settings to get it working.
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
Be sure to post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
burnz123 wrote:Is this product compatible with FIOS? If so, is there set up directions available somewhere to assist me in the set up?
