pkrockwell
Sep 05, 2021Aspirant
Orbi AX6000 NAT Type 3 - How to change for PS5 connection?
Orbi Router (RBR850) + one Orbi Satellite (RBS850) - When I log in to Destiny 2 servers on my Playstation 5, I recieve a notice that my internet connection is set to NAT type 3, which is limiting matchmaking for the game. How can I change my NAT type for this router? I looked in the advanced settings, and did not see any options to change this setting. Any help would be greatly appreciated!
Thanks.
MIght get more help in the orbi AX forum versus the mobile router forum.
Orbi (AX) - NETGEAR Communities
include what modem/gateway you have connected to your system when you post there.
- pkrockwellAspirantoops, thank you
Any progress on this?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?NAT 3 means you have a router in front of the RBR. If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
