Teampipeline
Nov 15, 2023Aspirant
Orbi AX6000 NO-IP Port Setting Help needed
We have been using the NO-IP DDNS service to remote into our router as needed for the last 6 months. The setup was very smooth, but part of that setup relied on the Remote Management Feature in the ...
- Nov 15, 2023
Teampipeline wrote:
I have not been able to find any clear guidance on how to setup port forwarding/port triggering to get the port open
As FURRYe38 pointed out, Netgear totally removed the web based Remote Management feature from Orbi routers. (Annoyed me no end. Their claim that Anywhere Access is an adequate replacement is sheer malarkey.)
DDNS (NO-IP is one of the three choices) has one purpose: to keep up with Internet Service Provider changes to customer public IP address. Every time the ISP changes your public IP address, the Orbi router informs the DDNS provider and their tables are updated. Since every DDNS provider has a unique method for updating information, Netgear functions with only the three DDNS providers listed in the drop down menu.
With the DDNS feature keeping track of "where IS this router today?", the user is able to make services available on the internet by forwarding ports on the router to specific devices on the Orbi LAN.
The substitute for Remote Management is to enable OpenVPN on the Orbi router. Once OpenVPN is enabled, the user can connect to the Orbi LAN from the internet using computers, laptops, tablets, smartphones, etc. I prefer to use a device that has a large enough screen to make the Orbi web interface usable, such as a laptop or tablet. With the device connected to the internet, use the OpenVPN Client to make a connection to the Orbi, then open a web browser to the LAN IP address of the router. This is usually 192.168.1.1.
If there is no internet connection, I create a Hot Spot on my cell phone. Connect the laptop to the Hot Spot. Then open the VPN client.
When OpenVPN is enabled on the Orbi, the required ports are opened automatically.
Nov 15, 2023Guru - Experienced User
https://kb.netgear.com/000062097/Remote-Management-is-now-Anywhere-Access-in-the-Nighthawk-and-Orbi-apps
https://kb.netgear.com/000065071/Why-is-the-Remote-Management-feature-being-removed-from-NETGEAR-routers
https://kb.netgear.com/000058239/How-do-I-enable-or-disable-Anywhere-Access-on-my-NETGEAR-or-Orbi-router
Something to contact NO IP about to get there configuration information for there services.
- TeampipelineNov 15, 2023Aspirant
I did, NO-IP is simply a DDNS to point towards your IP. They do not help configure the router ports.
