gobblegobble
Jul 29, 2020Aspirant
Orbi AX6000 (RBK852) SSID dissappears
I have an RBK852 (firmware V3.2.15.32_1.3.25) with 1 satellite. Recently I've been having issues where the SSID completely vanishes and all devices no longer have internet connection. When this happe...
Jul 29, 2020Guru - Experienced User
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- gobblegobbleJul 29, 2020AspirantI’ve tied all of that. Have even contacted Netgear support and purchased the extended protection plan before they would help me. At this point I wish I could return this device. $700 and it should work much better than it does.
- FURRYe38Jul 29, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?How was the FW updated?
How many devices do you have connected?
What devices do you have connected?
- gobblegobbleJul 29, 2020AspirantWhat is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Arris NVG589, AT&T Fiber
Yes
Roughly 30ft
2
Manually using a computer to install the hot fix FW as instructed by Netgear tech support
41
Computers, Phones, Tablea, Smart devices
