gobblegobble
Jul 29, 2020Aspirant
Orbi AX6000 (RBK852) SSID dissappears
I have an RBK852 (firmware V3.2.15.32_1.3.25) with 1 satellite. Recently I've been having issues where the SSID completely vanishes and all devices no longer have internet connection. When this happe...
Jul 29, 2020Guru - Experienced User
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
gobblegobble
I’ve tied all of that. Have even contacted Netgear support and purchased the extended protection plan before they would help me. At this point I wish I could return this device. $700 and it should work much better than it does.
- FURRYe38Jul 29, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?How was the FW updated?
How many devices do you have connected?
What devices do you have connected?
- gobblegobbleJul 29, 2020AspirantWhat is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Arris NVG589, AT&T Fiber
Yes
Roughly 30ft
2
Manually using a computer to install the hot fix FW as instructed by Netgear tech support
41
Computers, Phones, Tablea, Smart devices- FURRYe38Jul 29, 2020Guru - Experienced User
What mode is your modem working in? Modem only or router?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry this, turn OFF the RBS and just leave everything connected to the RBR. See if the problem continues.
Try the suggestions with AX and CTS values as well.
Yes
Roughly 30ft
2
41
