gobblegobble
Jul 29, 2020Aspirant
Orbi AX6000 (RBK852) SSID dissappears
I have an RBK852 (firmware V3.2.15.32_1.3.25) with 1 satellite. Recently I've been having issues where the SSID completely vanishes and all devices no longer have internet connection. When this happe...
Mikey94025
Jul 29, 2020Hero
gobblegobble wrote:I have an RBK852 (firmware V3.2.15.32_1.3.25) with 1 satellite. Recently I've been having issues where the SSID completely vanishes and all devices no longer have internet connection. When this happens I have to power cycle the router and then everything comes back.
Is the internet outage just wireless or does it also affect wired devices? Knowing this may help isolate which workarounds to try.
Do you know if you have Double NAT (i.e., your Arris also a router)? If the https://canyouseeme.org/ IP address is different from what orbilogin.com Advanced displays as your Internet Port IP address then you do have Double NAT and might try using the Orbi in Access Point mode instead of Router mode.
Besides the other suggestions, I also recommend setting CTS/RTS Threshold to 2347 to improve Orbi AX wireless compatibility with older devices. However, I think this only affects the SSID being visible at all to a particular device and would not explain the SSID appearing and then later disappearing.
gobblegobble
The Ethernet continues to work. I have placed the Arris router in “pass through mode” but it will be double NAT. My TV (U-verse) comes through the Arris router so it still has to do things for the AT&T cable boxes. Threshold is already 2347.
