ebachenh
Oct 06, 2020Aspirant
Orbi AX6000 (RBK853) and Motorola MM1002 Moca Adapter
Hi everyone: Now that I upgraded to Verizon Fios 1 Gig service, I was very excited to install my new Orbi AX6000 (1 router and 2 satellites) as my first generation Eero's didn't support speeds fa...
Mstrbig
Oct 06, 2020Master
Your 3rd option would be your best bet to get the Orbi router out of the basement.
If you are planning on hardwiring the satellites, they would have to be connected to the router or 1 satellite to router then the other satellite to the 1st satellite.
Adding a satellite may help if your satellites are to far apart or you have a lot of obstructions and interference reducing the signal strength and coverage.
