ebachenh
Oct 07, 2020Aspirant
Orbi AX6000 (RBK853) and Motorola MM1002 Moca Adapter
Hi everyone: Now that I upgraded to Verizon Fios 1 Gig service, I was very excited to install my new Orbi AX6000 (1 router and 2 satellites) as my first generation Eero's didn't support speeds fa...
Oct 07, 2020Guru - Experienced User
Basements are not recommended places for wifi routers. Main or 1st floor to start would best for the main host router..
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
ebachenh
The home is about 4000 sq ft with another 1000 in the basement.
The RSR is one one side of the home in the basement. The RSR1 is about the midpoint of the home on the main floor (goes up one level and otherwise about 30-40 feet away). The RSR2 is on the oppositte side of the RSR on the top floor and about 40-50 feet away from the RSR1.
I am going to run an Ethernet wire from my Verizon router to the main floor and see if that helps, plus ordered 2 more satellites to scatter if I still need more unless anyone has other suggestions?
- FURRYe38Oct 07, 2020Guru - Experienced User
Lets use RBR for the router and RBS for the satellites. :smileywink:
I have a 5000 sq ft home with basement. RBR is up on 2nd level and 1 RBS is on first level and 2nd RBS is in the basement on opposite side from where the RBR is on that side of the home. RBS are all wired here...
- ebachenhOct 07, 2020Aspirant
Sorry, I'm still learning the lingo as a noob! But will do!
Sounds like we have similarly sized homes and our set up completely oppositte from one another except that you have them all wires. My RBR is in the basement (until I run the Ethernet to main floor) because I only have coax runs through the house. I assume you either had or ran Ethernet to connect your satellites to RBR (or daisy chained)?
Running Ethernet to my main level will not be too difficult but it would be very challenging to run it up to the top floor (either from basement or from the Main level RBR that I intend to set up). Hopefully the network will improve and throwing on 2 more satellites will take care of things.
ebachenh wrote:Lets use RBR for the router and RBS for the satellites.
:smileywink:
Yes, I have ran ethernet cables from the 2nd level area where most of my elentronics and networking hardware is located down to the 1st level and basement area. I have a few LAN switches in place to help with connetions and wired devices including a switch in the basement where the one RBS is ethernet connected.
Running Ethernet to my main level will not be too difficult but it would be very challenging to run it up to the top floor (either from basement or from the Main level RBR that I intend to set up). Hopefully the network will improve and throwing on 2 more satellites will take care of things. Just be sure distance from the RBR and each other is at a good distance. Too close and can cause problems. I think you should first bring up the RBR to the 1st floor then test with your current RBS making adjustments were needed. You may not have a need for any more RBS...
- Mikey94025Oct 07, 2020Hero
ebachenh wrote:I am going to run an Ethernet wire from my Verizon router to the main floor and see if that helps, plus ordered 2 more satellites to scatter if I still need more unless anyone has other suggestions?
This sounds like a good first step to improve your Orbi network bandwidth. I would not complicate your setup by adding moca adapters to the mix and instead try to leverage the Orbi mesh capability via its satellites (at least before trying other options).
- MstrbigOct 07, 2020Master
ebachenh wrote:The home is about 4000 sq ft with another 1000 in the basement.
Your 3rd option would be your best bet to get the Orbi router out of the basement.
If you are planning on hardwiring the satellites, they would have to be connected to the router or 1 satellite to router then the other satellite to the 1st satellite.
Adding a satellite may help if your satellites are to far apart or you have a lot of obstructions and interference reducing the signal strength and coverage.
Another thought I just came up with. If you have COAX presently going to the G3100, as your connection to FIOS, and you have a COAX cable coming from the basement area, to the floor you want to move the Orbi to, you could possibly move the G3100 to that level and connect it via the COAX. Then plug your Orbi router into it and setup either a router or AP configuration.
Good suggestion but I think in leaving the G3100 router in the basement it will provide an access point outside the Orbi for the few ocassions someone would be in the basement and needing it. This effectively allows 3 other access points (RBR and 2 X RBS) to scatter throughout the home. If I move the router and put the RBR next to it, the router is effectively "wasted" as an access point, so I might as well take advantage of it being in the basement!
