gwhite66
Apr 23, 2024Aspirant
Orbi AX6000 (RBR850) - blocking one of my email addresses in/out
My RBR850 appears to be blocking one of my email addresses from receiving/sending to my laptop. When I connect directly to my cable modem, the traffic flows fine. When I reconnect to my RBR850 again,...
Apr 23, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter and IPv6.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
If emails have been working with the Orbi system and something started happening past few months, might be something with the email services. Or something changed on the Apple device?
- gwhite66Apr 23, 2024Aspirant
have not Comcast Xfinity Modem
PN: CGM4331COM
FCC ID: G954331X
I think I am using cat5, but literally nothing changed in the last few months (that I can identify) which would initiate the blocking of email. Certainly nothing physical on the setup.
Everything you suggested is blocked, except traffic meter, which I disabled (again, its been running for 2 years). Nothing changed on the apple device. Nothing I know changed on the email server side.
I have NOT done a factory reset & setup from scratch since last FW update - you'd think that a modern product would not require a complete build from scratch every time an over the air FW update was sent, but hey, I'll do it if there's a reasonable chance of fixing the problem!
- FURRYe38Apr 24, 2024Guru - Experienced User
Your ISP Modem already has a built in router and Wi-Fi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
2. If you can't bridge the modem, disable ALL Wi-Fi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all Wi-Fi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Lets try option #2 first...
PN: CGM4331COM
FCC ID: G954331X
- gwhite66Apr 24, 2024Aspirant
Apologies - the Xfinity modem is always in bridge mode, always has been.
