skywalker32cjj
Jul 16, 2021Aspirant
Orbi ax6000 rbr850 Best setup for at&t gateway and Xbox series x
Hi, I've been on the phone with at&t a few times and thought it was partially solved but still having problems. Isp put there gateway in ip passthrough with antennas off and left everything else alone...
- Jul 17, 2021Was on last night with at&t Support and what we did was put there gateway in ip passthrough. Closed all the ports we opened for xbox and put orbi ax6000 in router mode. They opened all the ports for the Xbox on the orbi and as of last night it was working. Open nat and I was able to get into socialclub.rockstargames.com To be able to play gta5 &red dead 2. I appreciate all the help. Thanks
skywalker32cjj
The at&t gateway is a BGW210-700. I've tried all those things with resetting Xbox, orbi and at&t gateway. When you said put modem in ip passthrough through orbi, does that mean I leave orbi in router mode? Also I saw some info online about disabling packets and firewall on gateway. Is this something I should do?
Jul 16, 2021Guru - Experienced User
Yes put the RBR in router mode when using IP pass thru.
You can try that on the modem as well, however that shouldn't interfer when you use IP pass thru...
- skywalker32cjjJul 16, 2021AspirantOk, thanks for the quick responses. On the upnp, I didn't see it in the at&t gateway settings. So I don't know if they did anything with that. Once I switch the orbi to router mode, I should be able to disable upnp or enable it on the orbi?
- FURRYe38Jul 16, 2021Guru - Experienced User
Should be able to keep uPNP enabled if your using IP Pass thru on the modem...
- skywalker32cjjJul 16, 2021AspirantJust tried with at&t gateway in ip passthrough and orbi in router mode. Just got double strict nat. Tried turning off upnp and got strict nat. I'm currently on the phone with at&t but I don't know if they'll be able to solve it. Should I open the ports for xbox on the orbi? Thank you for your time
