skywalker32cjj
Jul 16, 2021Aspirant
Orbi ax6000 rbr850 Best setup for at&t gateway and Xbox series x
Hi, I've been on the phone with at&t a few times and thought it was partially solved but still having problems. Isp put there gateway in ip passthrough with antennas off and left everything else alone...
- Jul 17, 2021Was on last night with at&t Support and what we did was put there gateway in ip passthrough. Closed all the ports we opened for xbox and put orbi ax6000 in router mode. They opened all the ports for the Xbox on the orbi and as of last night it was working. Open nat and I was able to get into socialclub.rockstargames.com To be able to play gta5 &red dead 2. I appreciate all the help. Thanks
Jul 16, 2021Guru - Experienced User
Should be able to keep uPNP enabled if your using IP Pass thru on the modem...
skywalker32cjj
Just tried with at&t gateway in ip passthrough and orbi in router mode. Just got double strict nat. Tried turning off upnp and got strict nat. I'm currently on the phone with at&t but I don't know if they'll be able to solve it. Should I open the ports for xbox on the orbi? Thank you for your time
- FURRYe38Jul 17, 2021Guru - Experienced User
Try this, set NAT Filter to OPEN on the RBR and see if this changes anything on the xbox.
- skywalker32cjjJul 17, 2021AspirantWas on last night with at&t Support and what we did was put there gateway in ip passthrough. Closed all the ports we opened for xbox and put orbi ax6000 in router mode. They opened all the ports for the Xbox on the orbi and as of last night it was working. Open nat and I was able to get into socialclub.rockstargames.com To be able to play gta5 &red dead 2. I appreciate all the help. Thanks
- FURRYe38Jul 18, 2021Guru - Experienced User
Glad they helped you get it working. Seems like there modem is working well for port usage.
Please mark your thread as solved so others will know.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. :smileywink:
