mickelsn
Apr 14, 2020Aspirant
Orbi AX6000 (RBR850) Spontaneous Rebooting
I recently purchased an Orbi Tri-Band AX6000 (RBK852) system which contains the RBR850 router and RBS850 satellite. The system is running in Access Point (AP) mode behind a FiOS Gateway as the only W...
Apr 14, 2020Guru - Experienced User
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
mickelsn
Apr 15, 2020Aspirant
I've absolutely had it with this system - it's rebooted twice in the space of an hour this morning as we put it under load with WiFi traffic from clients. The satellite is showing strong connection (blue light a little bit after reboot) until things go to crap (magenta solid light) and all client connections die until the router reboots. The fact that you can't get to any meaningful status information for a reasonably-informed user in the Web GUI hampers troubleshooting.
I've already got my RMA from NewEgg, and I will be finding another WiFi 6 router from a Netgear competitor; the meantime, I'm back to the Apple AirPort Extreme I've had running with absolutely no problems for the last few years. This product isn't up to my expectation of quality from Netgear.
