Keemostrauby
Nov 06, 2023Follower
Orbi AX6000 RBR850
I have recently added T-Mobile 5G Internet to my property. Can the Orbi AX6000 be set up with that equipment?
Nov 06, 2023Guru - Experienced User
Something to ask that ISP about.
Something to keep in mind as well:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
