Tai-HV-24
Jul 14, 2024Aspirant
Orbi AX6000 RBR850
On my cel, it connected to the router first then move my connection to my satellite, which is good for better connection speed. However on my PC with the satellite next to it, using off the shelve W...
CrimpOn
Jul 14, 2024Guru - Experienced User
It would help to know the brand/model of the USB WiFi adapter
Seamless roaming between WiFi access points is based on some 802.11 standards. It is up to the manufacturer to program the WiFi system. Devices obviously intended to be mobile (such as cell phones) usually have WiFi software that constantly scans for better connections and supports the roaming protocols. Some devices "quit looking" once they find a WiFi access point. For these devices, it is often necessary to power them off and back on again. For example, by "forgetting" the WiFi connection and then selecting it again from the list of available WiFi networks.
