Tai-HV-24
Jul 14, 2024Aspirant
Orbi AX6000 RBR850
On my cel, it connected to the router first then move my connection to my satellite, which is good for better connection speed. However on my PC with the satellite next to it, using off the shelve W...
Jul 15, 2024Guru - Experienced User
Some windows devices have in the device manager the option to change the roaming aggressiveness. You might check to see if yours does (if its on windows). here's intel's instructions on changing it.
- Tai-HV-24Jul 16, 2024Aspirant
Good news, I no longer has problems. The issue was my router speed was a little faster than the satellite at the test time, therefore my PC remains connected to the router. Now and then the speed fluctuate and my satellite is faster than the router, them my PC network connection would switch over to satellite. However the WiFi speed is just as bad as many other routers I had tried. Even connect to the satellite, my download speed was reduced to 1/3 of the 1G available speed. The satellite was upstairs half distance between the PC and the router, about 50-60ft away from router, 30ft from PC. At this time, I think I might have to cough up $ to get a good WIFI-6 stick to test it out. If you think/agree the WIFI stick could be the problem, any suggestion with which stick model would be good? I am also about to upgrade to 2G download internet service, so the wifi-6 stick must be able to handle close to that speed.
