Tai-HV-24
Jul 14, 2024Aspirant
Orbi AX6000 RBR850
On my cel, it connected to the router first then move my connection to my satellite, which is good for better connection speed. However on my PC with the satellite next to it, using off the shelve W...
Jul 18, 2024Guru - Experienced User
Is the PC a desktop or laptop model?
For PC, you might consider getting into a PCIe AX210 Wi-Fi adapter.
For Laptop, they have laptop upgrade adapter cards for them if your laptop has that ability to upgrade the Wi-Fi card. Something to contact the mfr of the laptop about.
For USB adapters, review items from here:
https://www.netgear.com/home/wifi/adapters/
Tai-HV-24 wrote:
On my cel, it connected to the router first then move my connection to my satellite, which is good for better connection speed. However on my PC with the satellite next to it, using off the shelve WIFI-5 USB3 stick, it connect to router with much slower speed and never move my connection to my satellite. How can I get my PC network connection to use the satellite ? Thx
I think it might have something to do with the WIFI stick, if so do I need WIFI-6 stick? Which good be good to work with Orbi WIFI-6? Thx
