Chuck_M
Nov 04, 2019Mentor
Orbi AX6000 shows "Offline" in Android App & Speed Lag
My new AX6000 was installed this weekend. Using my RBR50 in Access Point mode, it is hardwired to a distant end of my home and external building and is recognized as sattelites to the AX with backha...
Nov 04, 2019Guru - Experienced User
I would turn OFF the Orbi AC units while troubleshooting this first.
What version of the Orbi app are you using?
Does this show same thing with different device, iphone if you have one?
Be sure your connected to the RBR with the app.
What is the Mfr and model of the ISP modem your using with the RBR?
The Orbi AX is well capable of near 900Mbps speeds WAN to LAN.
Are you speed results from wired or wireless speed testing?
