Chuck_M's avatar
Chuck_M
Mentor
Nov 04, 2019
Orbi AX6000 shows "Offline" in Android App & Speed Lag
My new AX6000 was installed this weekend.  Using my RBR50 in Access Point mode, it is hardwired to a distant end of my home and external building and is recognized as sattelites to the AX with backha...
  • ekhalil's avatar
    Nov 04, 2019
    Chuck_M, nice to hear from you, long time no hear :)
    Please note that you can connect your wired RBS50's to the Orbi AX Router.
    The wireless RBS50 is currently not possible to add to the RBR850 but this will come later.
