karenesbs
Jul 20, 2022Aspirant
Orbi AX6000 Tri-band Mesh WiFi 6 - can only connect to guest on all devises
I unplugged my local modem and Orbi router this morning to clean the surface they sit on and when I plugged everything back up, my Orbi had a solid magenta light, so I repeated the unplug and replug ...
Jul 20, 2022Guru - Experienced User
Are you able to access the RBRs web page using a wired PC and web browser at 192.168.1.1
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- karenesbsJul 20, 2022Aspirant
"Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn on computers and rest of network."Yes, I did this three this morning after the initial unplugging - in that order
"Are you able to access the RBRs web page using a wired PC and web browser at 192.168.1.1"
I don't know what RBR's web page is, but when I tried going to 192.168.1.1, the page would not load, nor can I get to the orbilogin.com page
"What Firmware version is currently loaded?" v4.6.8.2
"What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?"Windstream T3260
