Sviel
Nov 26, 2020Follower
Orbi ax6000 wired?
Hi, is it better to hardwire the Router with the satellite? Thanks
michaelkenward
Nov 27, 2020Guru - Experienced User
Probably, that's usually recommended, but it all depends on the circumstances, which are a mystery to us given the limited details you provide.
You might get more help in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
