Sviel
Nov 26, 2020Follower
Orbi ax6000 wired?
Hi, is it better to hardwire the Router with the satellite? Thanks
Nov 27, 2020Guru - Experienced User
Most configurations depend on wireless envrionment, building materials, cable configuration, placement and distance. Wired will always have better performance and stability.
Be sure to visit the Orbi AX forum for any Orbi AX help and information.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
