Sviel
Nov 26, 2020Follower
Orbi ax6000 wired?
Hi, is it better to hardwire the Router with the satellite? Thanks
Nov 27, 2020Guru - Experienced User
"Orbi ax6000 wired?" Refers to the Orbi RBK 8 series.
CrimpOn
FURRYe38 wrote:"Orbi ax6000 wired?" Refers to the Orbi RBK 8 series.
True, but it also refers to:
EAX80 Nighthawk
RAX120v2 Nighthawk
SXK80 Orbi Pro
- FURRYe38Nov 27, 2020Guru - Experienced User
Agreed however I'll presume he's referenceing the RBK 8 series system since he referenced Orbi and AX6000...:smileywink:
FYI, I'm going to try out the EAX80. Will see how it does. :smileyvery-happy:
- michaelkenwardNov 27, 2020Guru - Experienced User
EAX80 Nighthawk
RAX120v2 Nighthawk
Neither of those is Orbi.
See my point?
Not much room for confusion.
I did check.
