nsapcor
Jan 21, 2020Tutor
Orbi AX6000 with RBK 853 on Spectrum
Spectrum advises it does not support the AX6000 router, i.e. it does not have access to the unit to make adjustments. My current Sagecomm router from Spectrum has been "optimized" to improve connect...
Jan 21, 2020Guru - Experienced User
No ISP support user bought routers or MESH systems.
If you have a ISP Modem that has built in router and wifi already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If your ISP router is already optimized for there services and you want better wifi and the use of AX, then I would suggest option#3...
- nsapcorJan 21, 2020Tutor
Perhaps I was not clear of what I intended. I have a separate modem and router from Spectrum. My preference would be to disconnect the Sagecomm router completely and connect the model directly to the Orbi system. assuming the AX6000/RBK853 is compatible with Spectrum
- FURRYe38Jan 21, 2020Guru - Experienced User
Then No. It's not thats its compatible, is that you need a modem of some form in front of the RBR or any external router. There needs to be a interfacing modem that services signal from the ISP. So you should check into Option #1 if my suggestion.
I will continue to use the existing modem provided by Spectrum (it is separate from the router) and merely replace the Sagecomm router with the Netgear Orbi equipment .
