nsapcor
Jan 21, 2020Tutor
Orbi AX6000 with RBK 853 on Spectrum
Spectrum advises it does not support the AX6000 router, i.e. it does not have access to the unit to make adjustments. My current Sagecomm router from Spectrum has been "optimized" to improve connect...
nsapcor
Jan 21, 2020Tutor
Perhaps I was not clear of what I intended. I have a separate modem and router from Spectrum. My preference would be to disconnect the Sagecomm router completely and connect the model directly to the Orbi system. assuming the AX6000/RBK853 is compatible with Spectrum
Jan 21, 2020Guru - Experienced User
Then No. It's not thats its compatible, is that you need a modem of some form in front of the RBR or any external router. There needs to be a interfacing modem that services signal from the ISP. So you should check into Option #1 if my suggestion.
- nsapcorJan 21, 2020Tutor
I will continue to use the existing modem provided by Spectrum (it is separate from the router) and merely replace the Sagecomm router with the Netgear Orbi equipment .
- FURRYe38Jan 21, 2020Guru - Experienced User
That should work fine then.
- TangmuJan 23, 2020Star
nsapcor wrote:I will continue to use the existing modem provided by Spectrum (it is separate from the router) and merely replace the Sagecomm router with the Netgear Orbi equipment .
I'm doing exactly that with Spectrum and the AX6000 with one satellite and no problems.
- FURRYe38Jan 23, 2020Guru - Experienced User
Thanks for letting us know it works for you. :smileywink:
