greywardens1
May 01, 2021Aspirant
ORBI AX6000 with Satellite VPN susceptible to Man in the Middle Attack
ORBI AX6000 Firmware V3.2.18.1_1.4.14 OpenVPN Server/Client I turned my logging up to 5 in the config. WARNING: No server certificate verification method has been enabled. See http://openvpn.net/...
May 01, 2021Guru - Experienced User
Best off to report this to NG support. Would be nothing that the forum can help with.
https://www.netgear.com/about/security/
Good Luck
- greywardens1May 01, 2021Aspirant
I did that, and thankfully I've got support on this product. I'll try to remember to post the recommendations/update once Netgear responds and/or fixes it.
- FURRYe38May 01, 2021Guru - Experienced User
Thanks.
- RehanSaeedOct 11, 2021Aspirant
Any updates on this issue?
I'm dealing with another VPN issue where Open VPN seems poorly configured. Wondering how I can get Netgear to fix it.
- FURRYe38Oct 11, 2021Guru - Experienced User
Best way would be to contact NG support and let them know what your seeing.
