rychder
Aug 16, 2020Tutor
Orbi AX6000 with Satellite
Recently purchased the Orbi AX6000 which includes a satellite. I am unable to connect an Epson printer NX420 to the network. Any suggestions? Is the printer too old? Thanks.
- Dec 10, 2020
Thanks for letting us know. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Gm4n
Dec 06, 2020Aspirant
Problem Solved for Epson NX420 and Orbi AX4200:
1. Restore printer to factory default settings.
2. On one laptop: deleted printer drivers then reinstalled driver (we downloaded online) like installing for the first time.
3. Continue setting up wifi connection with a temporary USB cable.
4. Done. Other devices can print like there was no issue.
Credit to https://community.netgear.com/t5/user/viewprofilepage/user-id/396301
Dec 08, 2020Guru - Experienced User
So do you leave the USB cable connected or no?
Thank for letting us know.
- Gm4nDec 09, 2020AspirantYou can remove USB cable when setup is done. You should be able to print through the wifi after that.
- rychderDec 10, 2020Tutor
Thank you for your suggestions. As it turns out, I decided to purchase a new Brother printer. After installation, it worked immediately with the Orbi network. So all is well in my printer world.
- FURRYe38Dec 10, 2020Guru - Experienced User
Enjoy. :smileywink:
