rychder
Aug 16, 2020Tutor
Orbi AX6000 with Satellite
Recently purchased the Orbi AX6000 which includes a satellite. I am unable to connect an Epson printer NX420 to the network. Any suggestions? Is the printer too old? Thanks.
- Dec 10, 2020
Thanks for letting us know. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Gm4n
Dec 09, 2020Aspirant
You can remove USB cable when setup is done. You should be able to print through the wifi after that.
rychder
Dec 10, 2020Tutor
Thank you for your suggestions. As it turns out, I decided to purchase a new Brother printer. After installation, it worked immediately with the Orbi network. So all is well in my printer world.
- FURRYe38Dec 10, 2020Guru - Experienced User
Enjoy. :smileywink:
