SRTrybusTutorAug 19, 2020Orbi AX6000 Can you use an AX4200 as an additonal sattelite on an AX6000 system with router + 2 satelites? The AX6000 individual satelites are not avaialble and I need another sattelite for coverage.
SRTrybusTutor to FURRYe38Aug 20, 2020so back to my question, does anyone know if you can use a 4200 sattelite in connection with a system that has a 600 router and two 6000 sattelties ?
SRTrybusTutor to SRTrybusAug 20, 2020edit - 6000 routerFURRYe38Guru - Experienced User to SRTrybusAug 20, 2020Yes you can.
