FrustratedOrbi1
Aug 24, 2021Aspirant
Orbi AX6000/rbr850 not working
Good Morning, Im at my witts end regarding my orbi rbr850 and satellites. I purchased in March of 2021, and was immediately pleased with the coverage and speed throughout my home. Fast forward to...
Aug 24, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? If not, please try this.
Also configure the RBR for these values after the reset:
FrustratedOrbi1
The modem is a hitreon coda 4589
I did do multiple factory resets on the router after the firmware upgrade, but i can do another one with the specs you listed
- FURRYe38Aug 24, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- FrustratedOrbi1Aug 24, 2021Aspirant
like i said in my original post, the modem is fully bridged
AH ok. I missed it. Ok then.
