bnandr
Aug 18, 2022Tutor
Orbi AXE11000 w/ HomeKit and Eve energy smart plugs. Bonjour/mDNS being blocked so no Thread network
Running firmware 6.0.3.85 and have Apple TV (2nd gen) and HomePod mini as Border Routers (15.6). Eve Energy plugs will not switch from Bluetooth to Thread over several weeks now. Tried running with d...
- Aug 26, 2022
Update: After returning all Orbi setting back to default except left IPv6 enabled, 3 days later I happened to check the Eve app and all the Eve Energy Smart Plugs had converted from Bluetooth to Thread. Wow, what an ordeal this has been but finally it happened. I don't think I mentioned that I went through this with a Linksys router for 2 months before switching to Orbi. Only problem is I have no idea what caused the transition to occur. Anyway, all plugs respond instantly no matter where they are in the house and when some of them are grouped, the group turns on and off all at the same time. Also, no more "unresponsive" from HomeKit. Thanks for everyone's input!
Aug 18, 2022Guru - Experienced User
Had this been working before?
Not sure if Thread protocols are supported on Orbi systems.
