dtay's avatar
dtay
Luminary
Jul 24, 2020
Orbi AX's traffic meter feature?
I just recently turned on the traffic meter feature (so I have an idea as to the usage on my network, even though I have unlimited) but then came across this post about how the traffic meter has a bug that slows the connection down?
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Issue-with-traffic-meter-slowing-down-internet-speed/td-p/1659221
Is this still an issue and does it manifest in the Orbi AX units?  If it does, then I'm going to disable it.
  • FURRYe38's avatar
    I haven't tried it lately. Do you see any issues since enabling it?
    • dtay's avatar
      dtay
      Luminary
      I haven't ran into any issues that I am aware of since enabling it this morning.
      This review (on the RBK852) had me wondering though; the reviewer had an issue with speeds slowing down until he disabled the option and factory reset his Orbi's.
      https://www.androidcentral.com/netgear-orbi-ax6000-router-review
      Excerpt from the review:
      "There is a strange issue I experienced which led to my download speeds being quite a bit less than they should have been. After some research, I found that some users experience similar issues when features like the traffic monitor were enabled. I performed a factory reset and my speeds were restored to full but I was unable to fully isolate the issue. I'm hoping it was a one time bug or something that can get fixed with an update. It was a bit annoying but not the end of the world."
      • FURRYe38's avatar
        Well if you don't notice anything with it enabled, maybe some differences with the reviewers configuration and FW. Don't know. Keep us posted if you notice anything with it enabled.
