elladss
Oct 28, 2022Aspirant
Orbi CBR750 - no light / power at all
Orbi CBR750 has no light / power at all... we had a thunderstorm that morning, system was connected to a power strip. We checked the breaker, it was tripped so we reset that. Tried taking the rou...
Oct 28, 2022Guru - Experienced User
I would try another power adapter to see if maybe the one you have was taken out by the storm. Often when this happens during storms, the power adapters are first to go.
If you have a power diagnostic meter you can test the tip of your power adapter while plugged in to see if you see any volts at the tip.
elladss
Thank you! I will purchase one and try once we receive it tomorrow. 🙂
- FURRYe38Oct 31, 2022Guru - Experienced User
Any updates on this?
- elladssOct 31, 2022Aspirant
Good morning! I've purchased a power supply from Amazon but found out that it had the wrong port connector -male, we needed the female. It had the same output 19V 3.16A. So I am returning this later on.
Opting to find one in BestBuy in-store for accuracy and assistance from the employees. If not available, I'll search again in Amazon with looking closely at the correct description.
Thank you for asking! I will let you know when there's another update.
