shotah
May 11, 2021Follower
Orbi CBR750 & TunnelBroker IPv6 Setup
How to configure IPv6 using tunnelbroker.net? https://tunnelbroker.net/ I can get it to work with other routers such as llinksys and eero, but I cannot get it to work with Orbi CBR750. I look...
CrimpOn
May 11, 2021Guru - Experienced User
A lot has happened since those instructions from 2012 for the WNDR4500. Orbi's support IPv6 natively, as do many ISP's.
A brief scan of their FAQ and forum did not turn up any mention of Orbi routers.
Just as a side note, the default Orbi configuration is not to respond to external ICMP, which is a requirement for TunnelBroker.
(This is an option that can be changed.)
Orbi may not be the product for you.
