drewbab1229
Aug 30, 2021Star
Orbi CBR750 Bad Firmware, cannot roll-back.
Netgear sent Firmware version V4.6.3.6_2.0.48 to my CBR750 which they have determined bad, and I have a few devices that will not connect now that the firmare has been pushed. If I try to roll-back ...
Aug 30, 2021Guru - Experienced User
What is wrong with your unit that v4 is not working?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
