drewbab1229
Aug 30, 2021Star
Orbi CBR750 Bad Firmware, cannot roll-back.
Netgear sent Firmware version V4.6.3.6_2.0.48 to my CBR750 which they have determined bad, and I have a few devices that will not connect now that the firmare has been pushed. If I try to roll-back ...
Aug 30, 2021Guru - Experienced User
What is wrong with your unit that v4 is not working?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
drewbab1229
Aug 30, 2021Star
They actually admitted it was their fault. However, they will do nothing. Worst company on this planet. Can't even roll-back the firmware, becuase the firmware they installed destroyed my device. Great Company!
- tman1973Nov 01, 2021Tutor
Same issue with my router. Called support and they have no other options than sign up for a support plan. Crazy. I beleive firmware issues are intentional so people will sign up for support. Bad business practice and I hope netgear would change. They should be providing patches to fix the issue rather than asking to pay for support and then they try to fix the issues. Totally unhappy.
- FURRYe38Nov 02, 2021Guru - Experienced User
