drewbab1229
Aug 30, 2021Star
Orbi CBR750 Bad Firmware, cannot roll-back.
Netgear sent Firmware version V4.6.3.6_2.0.48 to my CBR750 which they have determined bad, and I have a few devices that will not connect now that the firmare has been pushed. If I try to roll-back ...
drewbab1229
Aug 30, 2021Star
They actually admitted it was their fault. However, they will do nothing. Worst company on this planet. Can't even roll-back the firmware, becuase the firmware they installed destroyed my device. Great Company!
tman1973
Nov 01, 2021Tutor
Same issue with my router. Called support and they have no other options than sign up for a support plan. Crazy. I beleive firmware issues are intentional so people will sign up for support. Bad business practice and I hope netgear would change. They should be providing patches to fix the issue rather than asking to pay for support and then they try to fix the issues. Totally unhappy.
- FURRYe38Nov 02, 2021Guru - Experienced User
